Compare Z-Wave Thermostats
Need help sorting out the options? Use the comparison chart below to find the perfect product for your needs. If you have specific questions, don’t hesitate to  contact us directly for help!
HomeSeer Z-Wave Thermostat Comparison
Manufacturer
2GIG
GoControl
Honeywell
Trane
Model
CT100
ZWSTAT
HVAC System Type
Standard & Heat Pump
Heat (Fossil or Electric)
Up to 4 Stages
2 Stages
Single & Multi-stage
2 Stages
Cool
Up to 2 Stages
2 Stages
Yes
1 Stage
Heat Pump
Up to 2 Stages
3 Stages Heat
2 Stages Cool
Yes
Yes
Electric Aux Heat
Yes
Yes
Yes
Yes
Forced Air Zoned Heat
Up to 2 Stages
Not Specified
Not Specified
Not Specified
Forced Air Zoned Cool
Up to 2 Stages
Not Specified
Not Specified
Not Specified
2 Wire Hydro Valves
Yes
Not Specified
Not Specified
Not Specified
3 Wire Hydro Valves
Yes
Not Specified
Not Specified
Not Specified
Millivolt Heat
Yes
Yes
Yes
Not Specified
Controls
Touchscreen
Pushbutton
Touchscreen
Touchscreen
LCD Display
24 Volt C-Wire Powered
Battery Powered
Operating State Can Trigger Events
Onboard Scheduling
Notable Features
May be powered by batteries alone or with C-Wire.
Humidity Sensor
Field-upgradable firmware.
specifications subject to change without notice.
