Compare Z-Wave Wall Dimmers
Need help sorting out the options? Use the comparison chart below to find the perfect product for your needs. If you have specific questions, don’t hesitate to  contact us directly for help!
HomeSeer Dimming Wall Switch Comparison
Manufacturer
HomeSeer
GE / Jasco
Linear
Cooper
Model
12724
WD500Z
RF9540-N
Capacity - Incandescent
600 Watt
500 Watt
500 Watt
600 Watt
Capacity - LED / CFL
150 Watt
150 Watt
Not Published
300 Watt
Electrical
120V, 60 Hz
120V, 60 Hz
120V, 60 Hz
120V, 60 Hz
Requires Neutral
Yes
Yes
Yes
Yes
Supported Bulb Type
Incandescent, CFL, LED
3-Way Connection Type
Wired
Wired
Wireless
Wireless
3-Way Companion Model
12723
WT00Z
RF9542-Z
Z-Wave Plus (500 series module)
Double-tap, Triple-tap Event Triggers
Supports Central Scene Class
Supports Z-Wave Scene Class
Provides Instant Status
Programmable Dim Rate
LED Dim Level Indicator
Supports Z-Wave Associations
Software Reversible Paddle
N/A
Screw Terminal Connectors
Colors Available
White, Lt Almond
White, Lt Almond, Ivory, Brown, Black
White, Almond, Brown, Black
Alpine White, White Satin, Desert Sand, Silver Granite
ND - White, Lt Almond, Black
Colors Included
White
White, Lt Almond
White
Each Sold Separately
Warranty
1 Yr
1Yr
1 Yr
2 Yrs
Comments
Supports latest Z-Wave technology.
programmable indicator
includes white trimplate
LED bulb trim adjustment
Includes Separate Dim Bar
specifications subject to change without notice.
