FCC / IC Statement
The statement below applies to our HS-WD100+ wall dimmer and HS-WS100+ wall switch.
FCC / IC statement
The equipment has been tested and found to comply with the limits for a Class B Digital Device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment uses, generates and can radiate radio frequency energy and, if not installed and used in accordance with the instruction, may cause harmful interference to radio communication. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
  • Reorient or relocate the receiving antenna
  • Increase the separation between the equipment and receiver
  • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected
  • Consult the dealer or an experienced radio/TV technician for help
Operation is subject to the following two conditions:
  • This device may not cause interference
  • This device must accept any interference, including interference that may cause undesired operation of the device.
Important Note: To comply with the FCC RF exposure compliance requirements, no change to the antenna or the device is permitted. Any change to the antenna or the device could result in the device exceeding the RF exposure requirements and void user’s authority to operate the device.
Caution: Exposure to Radio Frequency Radiation. To comply with FCC/IC RF exposure compliance requirements, a separation distance of at least 20 cm must be maintained between the antenna of this device and all persons. This device must not be co-located or operating in conjunction with any other antenna or transmitter.
This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions:
  1. this device may not cause interference, and
  2. this device must accept any interference, including interference that may cause undesired operation of the device.
DÉCLARATION FCC
Cet équipement a été testé et déclaré conforme aux limitations prévues dans le cadre de la catégorie B des appareils numériques selon la définition de la section 15 du règlement de la FCC. Ces limitations ont été conçues pour fournir une protection raisonnable contre tout brouillage nuisible au sein d’une installation résidentielle. Ce dispositif génère, utilise et diffuse des ondes radio et, s’il n’est pas installé ni utilisé en conformité avec les instructions dont il fait l’objet, peut causer des interférences gênantes avec les communications radio. Nous ne saurions toutefois garantir l’absence d’interférences dans une installation particulière. Si ce dispositif produit des interférences graves lors de réceptions radio ou télévisées qui peuvent être détectées en allumant et en éteignant le dispositif, vous êtes invité à les supprimer de plusieurs manières:
  • Réorienter ou déplacer l’antenne de réception.
  • Augmenter la distance séparant l’équipement et le récepteur.
  • Connecter l’équipement à un circuit différent de celui auquel le récepteur est connecté.
  • Contacter votre revendeur ou un technicien radio/TV qualifié.
Toutes modifications ou tous changements effectués sans l’accord exprès de la partie responsable de la compatibilité pourraient annuler le droit de l’utilisateur à utiliser son dispositif. Si des câbles d’interface blindés ont été fournis avec le produit ou si des composants ou des accessoires complémentaires sont recommandés, ils doivent être utilisés lors de l’installation du produit afin d’assurer la conformité avec le règlement FCC.
Cet appareil est conforme aux normes RSS exemptées de licence d’Industrie Canada. L’opération est soumise aux deux conditions suivantes:
  1. Cet appareil ne doit pas provoquer d’interférence, et
  2. Cet appareil doit accepter toute interférence, y compris les interférences susceptibles de provoquer un fonctionnement indésirable de l’appareil.
