Our Smart Home Hub Family
HomeSeer offers a smart home hub for every need & budget. Our HomeTrollers are powered with our award winning HS3 home automation system software and include our free mobile appremote access service! Each HomeTroller features locally processed automation for unparalleled performance, reliability, security & privacy. Our hubs also work seamlessly with Amazon & Google smart speakers and we’re a proud IFTTT integration partner.
Why Choose HomeSeer?
Our systems are the culmination of more than 20 years of research and development. Our software is simply the most flexible home automation program ever devised. In a nutshell, if you can’t do it with HomeSeer, it probably can’t be done at all! Check out these important features:
Reliable & Fast
Automations are processed locally for the highest level of performance with no delays.
Safe & Secure
All your information is stored on your system at home, not in the cloud.
Internet Independent
Automations continue to fire even if your Internet connection goes down.
Compatible
HomeSeer works with thousands of popular products from hundreds of companies.
Leverage The Cloud
HomeSeer is compatible with Amazon & Google smart speakers & with IFTTT.
Future Proof
Our systems don’t rely on a web platform. Your smart home investment is secure.
Smart Hubs For Every Need & Budget
HomeTroller Zee S2 Home Controller
HomeTroller Zee S2
HomeTroller Zee S2 Is An Advanced Home Controller. It Combines The Speed & Reliability Of Locally Managed Automation With The Power Of Cloud-Managed Services. The Unit Is Powered By HS3-Pi Home Automation Software And It Supports Enough Smart Home Devices To Satisfy All But The Most Demanding Automation Needs.
  • Home Controller with S3-Pi3 Software
  • Controls Light Switches, Thermostats, Door Locks, Garage Doors, Water Valves, Energy Monitors, Environmental Sensors, Cameras and More
  • Built In Z-Wave Radio (US edition only)
  • Includes Free HomeSeer Mobile app for Apple and Android Devices
  • Includes Free MyHS Remote Access Service
  • Supports Your Choice of Up to 5 Linux Plug-ins (including pre-installed Z-Wave plug-in)
  • Works with Amazon Alexa & Google Home Assistant Devices
  • Directly Supports Google Voice Control from any Android Device
  • IFTTT Compatible – Works with Hundreds of Web Products, Apps and Services
  • Can issue spoken messages for alerts, announcement and reminders
  • Fully Customizable Email and Text Alerts
HomeTrollers process all your automation locally, ensuring the highest level of reliability and performance. You won’t experience the “delays” that are common with Internet-reliant solutions like typical ‘smart hubs’ and ‘gateways’.
Safe & Secure
Every HomeTroller is designed to store all your sensitive information right there at home, never in the cloud. This helps to prevent hackers and prying eyes from seeing your personal data and custom home automation schedules.
Internet-Independent
Our MyHS web service simplifies the process of controlling your home remotely but is not required to automate your home. Your HomeTroller will continue to control your home 24/7, even when the internet is down or there’s a web service outage.
HomeTrollers are designed to work with thousands of products from hundreds of manufactures using most popular home automation technologies. With HomeSeer, your imagination is your only limitation!
Amazon Echo / IFTTT / Google Home
Leverage the latest technology with your HomeSeer-powered home! Use Amazon’s popular ‘Echo’ or a Google Home device to control your home by voice and create IFTTT ‘Recipes’ that integrate with more than 300 web products, apps and services from around the world!
  • UPC: 610585164334
  • CPU: ARM Cortex-A53 CPU (1.2 GHz, 4 core)
  • RAM: 1 GB
  • Storage: 8 GB SD
  • 4 USB Ports
  • LAN Port
  • HDMI Port
  • Linux OS
  • Includes built-in Z-Wave Plus certifed interface (US)
  • Built-in WiFi
  • AC Power Adapter: c(UL)us approved, 100-240v, 50/60Hz in, 5v 1a out, US style plug
  • Unit Dimensions: 4.4″ x 3.8″ 1″ (113mm x 97mm x 27mm)
  • 3 watt power consumption
  • Works with your choice of up to 5 software plug-ins (drivers)
HomeTroller-SEL Home Controller
HomeTroller SEL
HomeTroller SEL Is Our Premium Grade Home Controller. It Combines The Speed & Reliability Of Locally Managed Automation With The Power Of Cloud-Managed Services. Hometroller SEL Is Powered By HS3 Home Automation Software And Includes Enough Available Ports To Satisfy Virtually Any Automation Need.
  • Home Controller with HS3 Software (SEL PRO edition includes HS3PRO)
  • Supports All Linux Plug-ins (Drivers)
SEL PRO Edition Extra Features
  • Includes HS3Touch Designer Mobile App Design Software (reg $299.95)
  • Includes Z-Seer+ Z-Wave diagnostics Software (reg $39.95)
  • Includes Z-Flash Z-Wave OTA Firmware Updater (reg $29.95)
Safe & Secure
  • UPC: 610585164242
  • Control Software: HS3
  • OS: Linux
  • CPU: Intel Celeron N2807 CPU (1.58 GHz, 2 core)
  • RAM: 2 GB
  • Boot Time: < 20 Seconds
  • Storage: 32 GB SSD
  • Ports: LAN, 3x USB, HDMI, VGA, Split Audio
HomeTroller S6 PRO
Hometroller S6 PRO Is Our Professional Grade Home Controller. It Combines The Speed & Reliability Of Locally Managed Automation With The Power Of Cloud-Managed Services. Hometroller S6 PRO Is Powered By HS3PRO Home Automation Software, Includes An Industrial Grade Chassis And Has Enough Ports To Satisfy Virtually Any Automation Need.
  • Home Controller with HS3PRO Software
  • Supports All Windows Plug-ins (Drivers)
Safe & Secure
  • UPC: 610585164303
  • Embedded Control Software: HomeSeer HS3PRO
  • Operating System: Windows 10
  • Processor: Intel Celeron 3205U CPU (1.5 GHz, 2 core)
  • Memory: 4 GB RAM
  • Storage: 120 GB SSD
  • Ports: (2) RS232, (6) USB, Mic in/Line out, (2) 10/100/1000 LAN, HDMI, Display Port
  • Power Consumption: Less than 15 watts (nominal)
  • Dimensions: 8″w x 6.5″d x 1.5″h
  • Power Supply: Universal 120-240v, 50/60Hz (US plug)
  • Certifications: UL, CE, RoHS
Home Controller Reviews
“Love it! Have been running HS2 on a dedicated, regular, computer for several years. The Home Troller S6 Pro controller is very compact, extremely well designed and incredibly stable. It is designed and dedicated to HS3. Delighted with the unit and the HS3 software.
Robert H (US)
“Sweet little controller Using it now for existing X10 items, but will be upgrading to UPB soon. So far I’m coming up the learning curve and the controller and software seem to be pretty flexible and easy enough to setup… and I’m no programmer by any stretch of the imagination.
Robert L (US)
“Very Pleased with my SEL
I moved from a Vera system to HomeSeer. HomeSeer has so many features, all easy to use. I needed help from support for 2 issues, both were answered quickly…
Christopher L (US)
“My Second Zee S2 I am so impressed with the first one that I bought, I purchased another for a different building. Setup was easy and controlling devices is very intuitive… Compared to what I have read about SmartThings, Wink, etc. I feel that I made the right decision.
Thomas C (US)
Smart Home Apps
HomeTrollers are designed to be programmed with any computer running Chrome, Safari or Firefox. We also provide two mobile apps (HomeSeer Mobile & HS3Touch Client) for system access and control. A third mobile app (Z-Tool+) simplifies Z-Wave smart device setup.
For Custom Integrators
HS3Touch Client App
Our Standard App
HomeSeer Mobile
Easy Z-Wave Network Setup
Z-Tool+
This website uses cookies to achieve the best user experience.
