Other HomeSeer Products
_8104173_orig[1]
SmartStick+ Z-Wave USB Interface
SmartStick+ is a Z-Wave USB interface for advanced home automation systems (like ours!). Z-NET supports the latest Z-Wave Plus technologies and includes a highly optimized antenna design for superior range and performance.
SmartStick+ may be combined with Z-NET remote interfaces for systems with multiple Z-Wave networks.
_1875701[1]
Z-NET Remote Z-Wave Interface
Z-NET is a remote Z-Wave network interface for advanced home automation systems (like ours!). Z-NET supports the latest Z-Wave technologies and includes a highly optimized antenna design for superior range and performance. Since Z-NET is IP-based, it may be installed virtually anywhere in the home. The unit includes a built-in LAN port and an optional USB-WiFi adapter is also available.
Each Z-NET can be configured to work with up to 232 Z-Wave devices, including light switches, thermostats, door locks, sensors and more. Additional Z-NETs may be installed in larger residences or in properties with outbuildings such as detached workshops, garages, barns or servant quarters.
9451100[1]
MyHS Remote Cloud-based Remote Access Service
  • Provides Remote Access to HomeSeer Web Interface and Mobile Apps
  • Allows Quick and Easy Remote Setup for All HomeSeer HS3 Systems
  • Eliminates Router Settings Changes
  • Eliminates Need for DDNS (Dynamic DNS Address) Service
The basic FREE service provides remote access for one system. A premium version is also available for dealers and users with multiple systems.
150485444[1]
HomeSeer Analog / Digital System Interface
Our ADIO-100 is designed to integrate a variety of non Z-Wave sensors with HomeSeer software and controllers. Use with the following:
  • Wired motion sensors
  • Wired door / window sensors and contact switches
  • Relay-actuated security panel zones
  • Dakata Alert Outdoor vehicle and intruder sensors
  • Wired analog senors (temperature, humidity, light level, water flow, pressure, etc)
_2620431[1]
HomeSeer HSM200 Multisensor | Indicator Module
Our new line powered Z-Wave multisensor detects motion, temperature & light level, can function as a night light and can display up to 7 different glowing colors when things happen in the home! Since it’s externally powered, there are no batteries to replace and it functions automatically as a Z-Wave network repeater.  Use with any HS3-based system to change color when motion is sensed, doors are opened, water leaks are detected or just about anything that happens in the home!
