GetPageHeader
Purpose
This procedure, useful when creating your own Active Server web Pages (ASPs) allows you to use HomeSeer's page header generating function with parameters that allow you to get all or part of the header information.
Parameters
Parameter: title
Type: string
Description: The title for the web page to be displayed at the top of the page before the logo bar.
Parameter: extra_meta
Type: string
Description: This parameter allows you to specify additional HTML to be included in the HEAD section of the page, and it should be formatted as a complete <meta ...> tag.
Parameter: HSOnload
Type: string
Description: This parameter is used by HomeSeer to specify Body_OnLoad procedures in the resulting page.  They are prepended to the "Web Site" configuration item of the same name.
Parameter: ExcludeNavLinks
Type: Boolean
Description: If TRUE is passed to this parameter, the navigation links will not be included in the output.
Parameter: NoHeader
Type: Boolean
Description: If TRUE is passed to this parameter, the HTML tag and all contents of the HEAD section will be excluded from the output.  The HEAD section includes the META tags, the page title, and the BODY tag (and thus Body_OnLoad is excluded).
Optional Parameter: HeadContentOnly
Type: Boolean
Description: If set to TRUE, only the contents of the HEAD html tag will be returned - use this if you are generating the other page elements yourself.  See the "NoHeader" parameter for information on what is included in the HEAD tag section.  The default value if this parameter is not specified is FALSE.
Optional Parameter: BodyContentOnly
Type: Boolean
Description: If set to TRUE, only the contents of the BODY html tag will be returned - this includes any Body_OnLoad specifications that are passed with the "HSOnload" parameter or the user's Body_OnLoad configuration value.  This is useful when generating your own web pages but wish to maintain the user's Body_OnLoad options which may be used with other plug-ins in the system.  The BODY tag is included in the output.  The default value if this parameter is not specified is FALSE.
Optional Parameter: BodyOnLoadOnly
Type: Boolean
Description: If set to TRUE, only the contents of the "HSOnload" parameter and the user's Body_OnLoad configuration value.  See "BodyContentOnly" for a usage scenario.  The BODY html tag is not included in the output.  The default value if this parameter is not specified is FALSE.
Returns
A string value containing the HTML content specified through the parameter choices.
A summary of a complete HomeSeer generated page header are as follows:
