This function forces an event to be triggered.
Parameter: name
Type: string
Description: This is the name of the event you want to trigger. The
actions for the event are executed. Note
that the name is not case-sensitive. For
instance, the events "Evening" and "evening" would
be considered the same.
If there were duplicate event names, only the first one found would run.
Return value: status
Type: integer
Description: This is 0 if there was
an error or 1 if there was no error. If
an error is detected, then an error message is written to the event log.
'Trigger the event named "turn all lights on"
sub main()
hs.TriggerEvent "turn all
lights on"
end sub
