HomeSeer Z-Wave Water Valves
Water damage from leaky toilets, sinks, water heaters and clothes washers can cost thousands of dollars to repair. HS-WV100+ is designed to work with popular home automation controllers, smart hubs and water sensors to stop the flow of water when leaks are detected. The unit may also be used for a variety of other irrigation or water regulation needs.
Perfect for...
  • Homes
  • Businesses
  • Rental properties
  • Vacation homes
  • Apartment complexes
  • Condos
Applications
  • Shut off water when leaks are detected
  • Regulate outdoor spigots & showers
  • Control irrigation
  • Use anywhere water control is desired
1665860[1]
HS-WV100+ Wireless Z-Wave Plus Water Valve
Our water valve system is designed to work with popular home controllers and hubs to stop the flow of water when leaks are detected.
Features
  • May be configured to work with home controllers or directly with water sensors
  • Available in 3/4" and 1" sizes
  • Easy to support Z-Wave "binary" device
  • Valve includes manual override
Specifications
  • Power: 100-240 VAC, 50/60 Hz
    Output: 12 VDC
  • Valve: Threaded 3/4" or 1"
    Certification: NSF
  • Z-Wave frequency: 908 MHz
  • Z-Wave version: ZDK v6.5x
  • Z-Wave Plus certified
