Amazon Alexa Integration
Control Your Home By Voice
We offer 2 powerful ways to control your home by voice
These skills may be used simultaneously or you can use the guide below to choose the skill that best fits your lifestyle.
Smart Home Skill
Smart Home Skill
This skill is available for use with English, Spanish & French accounts
Key Features
  • Easy to Set Up
  • Supports Alexa Routines
  • Simple Voice Commands
Sample Syntax
“Alexa…
  • … turn off the kitchen light”
  • … set the thermostat to 65 degrees”
  • … dim the porch light to 50%”
  • … open the garage door” (Requires Routine)
Home Automation Skill
This skill is available for use in the US
Key Features
  • Easy to Set Up
  • Works with All HomeSeer Devices & Events
  • Can Get Status From Devices
  • Supports Time Delays
Sample Syntax
“Alexa, Tell HomeSeer to…
  • … close the garage door”
  • … in 10 minutes, lock the front door”
  • … get the status of my temperature sensor”
  • … run the SUNSET event”
This website uses cookies
