LED Bulb Comparison
Need help sorting out the options? Use the comparison chart below to find the perfect product for your needs. If you have specific questions, don’t hesitate to contact us directly for help!
LED
Bulb Performance Comparison |
This
chart reflects the relative performance of some popular dimmable
120v / 60hz LED light bulbs when used with
our HS-WD100+ Z-Wave
wall dimmer controlled by a HomeSeer HS3 (HomeTroller) system. |
Photo |
Manufacturer | Cree
Cree
Ecosmart
Phillips
Phillips
Sylvania
UtiliTech
PRO
Model | BA19-08027
BA19-11050
A810SS |
455857
458737
79160
740062
Actual Wattage | 10
Watt
13.5
Watt
9
Watt
9.5
Watt
7
Watt
8.5
Watt
8.5
Watt
Equivalent Bulb Rating | 60
Watt
75
Watt
60
Watt
60
Watt
40
Watt
60
Watt
60
Watt
Lowest Visible Dim Level | 3%
1%
52%
1%
13%
1%
6%
Lowest Flicker-Free Dim Level | 10%
1%
52%
1%
13%
10%
6%
Max Brightness Dim Level* | 55%
80%
84%
85%
90%
75%
80%
Highest Flicker-Free Dim Level | 98%
98%
88%
98%
98%
98%
98%
Notes |
Bulb
has relatively small usable dim range and flickers slightly below
10%
Wide
usable dim range
Bulb
has very small usable dim range and flickers constantly above 88%
The
widest usable dim range of this grouping
Intermittent flickering was observed in the 50-60% dim range.
Daylight
Color Temp
Recommended (flicker-free when dimmed to 10% or higher) |
specifications
subject to change without notice. *Max Brightness Dim Level refers to the maximum dim level setting that produces a measurably brighter appearance. |
