MyHS Remote Access Service
The easy way to connect to your HomeSeer home!
with MyHS, you’re always in touch with your home. Setup is simple and straightforward. There’s no need to mess with your router or home network settings. MyHS works automatically in the background 24/7. MyHS is available in these 2 versions:
- The standard (Free) version supports one HomeSeer system with one set of login credentials.
- The premium version supports multiple HomeSeer systems and multiple login credentials. Learn more about MyHS Premium.
Step 1: Create Your Account
Navigate to https://myhs.homeseer.com/register and complete the form. Enter your HS3 License ID and Password at the bottom.
HomeTroller users: Your HS3 license is printed on the bottom panel of your unit.
Step 2: Sign In To Your Account
Navigate to https://myhs.homeseer.com/, enter your account credentials and click “Access System” to load your HS3 web interfaces. If you need to change your credentials, click “Manage Account”
