Our Family of Products
Smart Home Hubs
HomeTroller Pi
Our simplest, most affordable hub is still light years ahead of the competition. HomeTroller Pi is powered with HS4 software running on a Raspberry Pi computer. Very affordable, easy to set up and manage.
HomeTroller Plus
Our mid-level hub offers a step up on performance and flexibility. HomeTroller Plus is powered with HS4 Std software on a Windows 10 computer. Very flexible, easy to set up and manage.
Smart Home Software
HS4 Std
Use HS4 to build your own smart home hub. The software runs virtually any Windows or Linux platform and features locally managed automation for the highest level of performance, reliability and privacy.
Z-Wave Interfaces
USB Dongle
SmartStick G8 is an 800 series Z-Wave Plus USB dongle that’s designed to integrate with home automation software (or hubs) and will send and receive Z-Wave commands in a Z-Wave network.
Network Interface
Z-NET is a Z-Wave Plus (908 MHz) network-connected interface that’s designed to integrate with home automation software (or hubs) and will send and receive Z-Wave commands in a Z-Wave network. Euro (868 MHz) version also available.
Lighting Products
Wall Dimmer & Switch
HS-WX300 is a Z-Wave Plus (908 MHz) wall switch that may be paired to the hub as a dimmer or on/off switch. It may be installed with or without a neutral wire and it includes multi-tap scene control and RGB LEDs that may be programmed to glow or blink different colors when things happen in your home.
Z-Wave Sensors
Multi-sensor
HSM200 is a Z-Wave Plus (908 MHz) multi-sensor that reports motion, temperature and light levels. The unit is line powered so it never needs batteries and works as a Z-Wave repeater. Very easy to install – jut plug it in and add it to your Z-Wave network.
Floodlight Sensor
HS-FLS100-G2 is a Z-Wave Plus (908 MHz) floodlight sensor that’s designed to control floodlights and to send Z-Wave commands when motion is sensed or when the light level changes. Installs as a replacement for a conventional floodlight sensor.
Motion Sensor
HS-MS100-G2 is a Z-Wave Plus (908 MHz) PIR sensor that’s designed to send Z-Wave commands when motion is sensed or has not been sensed for a period of time. A long life lithium battery is included.
Leak Sensor
HS-LS100+ is a Z-Wave Plus (908 MHz) water leak sensor that’s designed to send Z-Wave commands when water is sensed and then not sensed for a period of time. A long life lithium battery is included.
Door / Window Sensor
HS-DS100+ is a Z-Wave Plus (908 MHz) door / window sensor that’s designed to send Z-Wave commands when doors or windows are opened and closed. The unit is powered with easy to source AAA alkaline batteries.
Water Management
Water Valve
HS-WV100+ is a Z-Wave Plus (908 MHz) motorized water valve that’s designed to respond to wireless commands to stop or allow the flow of water. The unit is available in 3/4″ and 1″ sizes and works with most homes and businesses.
