HomeSeer Security Cameras
Protect your home and family with our high resolution indoor & outdoor security cameras.
HS-CAM-I Pan & Tilt Indoor Security Camera
HS-CAM-I is a high resolution (1080P) indoor WiFi security camera with pan & tilt features. The unit is easy to set up and works nicely with all HomeSeer smart home software & hubs.
Features
- 1080P Resolution
- WiFi Connectivity
- Night Vision
- IR Cut Filter
- Pan & Tilt Operation
- Works With HomeSeer Smart Home Software & Hubs
Operation
Just pair with your WiFi network and follow the install guide to configure with your HomeSeer system. Video will appear on Cameras tab in HomeSeer Mobile.
- Resolution: 1080P (1920 x 1080)
- Lens: 3.6mm
- Pan & Tilt Range: 240° (H) x 60° (V)
- Night Vision Range: 20 ft | 6 m
- WiFi: 802.11 b/g/n (2.4 GHz)
- Optional Storage: Up to 128 GB MicroSD
- Power: DC 5V 6W
- Dimensions: 3.1 x 3.1 x 4.3″ | 79.5 x 79.5 x 110mm
HS-CAM-O Outdoor Security Camera
HS-CAM-O is a high resolution (1080P) outdoor security camera that connects to your home network via Ethernet or WiFi. The unit is easy to set up and works nicely with all HomeSeer smart home software & hubs.
Features
- 1080P Resolution
- Ethernet or WiFi Connectivity
- Night Vision
- IR Cut Filter
- Weather Proof Housing
Operation
Just pair with your WiFi network or connect to your wired Ethernet network and follow the install guide to configure with your HomeSeer system. Video will appear on Cameras tab in HomeSeer Mobile.
- Lens: 4mm
- Sensor: 1/2.7″ CMOS
- Night Vision Range: 80 ft | 25 m
- Weather Rating: IP66
- Power: DC 12V 7W
- Dimensions: 7.1 x 2.6 x 2.6″ | 180 x 67 x 67mm
