Protect Your Home From Water Damage
HomeSeer Smart Water Valves
Water damage from leaky fixtures & appliances cost homeowners thousands of dollars every year. Our smart water valves are designed to to notify you and to stop the flow of water when leaks are detected.
HS-WV100+ Z-Wave Water Valve
HS-WV100+ is a Z-Wave Plus certified water valve control system that may be remotely or automation controlled to mitigate water damage when leaks are detected. This water valve controller may also be used to regulate water usage and to control irrigation equipment. HS-WV100+ is available in 3/4″ & 1″ valve sizes.
Perfect For…
- Homes
- Businesses
- Rental properties
- Vacation Homes
- Apartment complexes
- Condos
- Wireless Z-Wave enabled water valve control system
- Use with HomeSeer (and other) home automation systems to remotely and/or automatically control the flow of water
- Use with water sensors to automatically shut water off when leaks are detected
- Use to regulate water usage for outdoor spigots, showers, sinks or irrigation equipment
- Valve includes manual override
This Z-Wave Plus motorized water valve may be used for a variety of applications. In particular, it can be used to mitigate damage caused by burst pipes or leaky sinks, toilets, hot water heaters, washing machines and more. HS-WV100+ may also be used to regulate water consumption for irrigation systems, showers and other uses.
Applications
- Link with Z-Wave water sensors to instantaneously shut off water when leaks are detected
- Use with home automation systems for more advanced and flexible applications
- Regulate outdoor spigots & showers
- Use as an irrigation system zone controller
- Use anywhere water control is desired
- UPC: 610585164440 (3/4″)
UPC: 610585164457 (1″) - Compatible with US Z-Wave networks (908 MHz)
- Valve circulation medium: Fluid, Air
- Valve body material: Stainless steel
- Valve life expectancy: 70,000 activations
- Valve maximum working pressure: 1.0MPa
- Valve max. torque force: 2 Nm
- Valve operating voltage: DC12V
- Valve working current: ≤ 500MA
- Valve open/close time: ≤ 5 Sec
- Valve environment temperature -15°C~50°C
- Valve liquid temperature range: 2°C~90°C
- Valve protection class: IP67
- Valve safety certification: NSF
