Z-Wave Interfaces
Every Z-Wave smart home system needs a Z-Wave “radio” or interface to connect with installed devices. Most smart hubs, like our HomeTroller Pi, have built-in interfaces, but advanced systems may need separate ones. The interfaces below are compatible with all HomeSeer and Home Assistant software and hubs.
SmartStick G8 800 Series Z-Wave Plus USB Stick
SmartStick G8 is a Z-Wave Plus V2 USB stick for use with HomeSeer, Home Assistant, and other Z-Wave compatible smart home software. SmartStick G8 offers extended wireless range and better security compared to previous SmartStick models. SmartStick G8 may be used with Z-NETs for a centrally managed, muti-network installation.
- Z-Wave Plus V2 (800 Series) Interface for use with HomeSeer and other brand software and hubs
- Supports Z-Wave Plus V2 (and older) Products
- Upgrade-able from Series 500 or 700 controllers running ZDK 6.61 or higher (requires HomeSeer Z-Wave Plus plugin or ZWave JS UI 9.9.0 or later).
- Supports Z-Wave S2 Security + Secure Vault™ – Requires Compatible Software or Hub
- Supports Z-Wave “Smart Start” Inclusion – Requires Compatible Software or Hub
- May be Used with Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
- Supports multiple Z-Wave frequencies when used with HomeSeer software or hubs.
Upgrade-able
Upgrade to SmartStick G8 from any 500 series or 700 series controller running ZDK version 6.61 or later. Upgrades may ONLY be performed using HomeSeer’s Z-Wave Plus plugin or Z-Wave JS UI version 9.9.0 or later. DO NOT use PC Controller or Simplicity Studio to perform an NVM upgrade. That will render the stick unusable and will void its warranty.
SmartStick G8 offers the same Z-Wave Plus benefits of our Z-NET interface at a fraction of the cost. This USB dongle performs best when positioned near the center of the home.
- Z-Wave Plus V2 Certified
- Protocol: Sigma Serial API
- Built-in 800 Series Z-Wave Module
- Includes ZDK 7.20.2 or later
- Field-up-gradable Firmware
- Compatibility: Any Z-Wave certified smart home software or hub (including all HomeSeer systems) running under Linux or Windows 7 (or higher).
- For Systems running Windows 7: SmartStick G8 Driver
- Windows Installation Instructions
- Manual
- All Documentation
Z-NET 800 Series Network Z-Wave Plus Controller
Z-NET G8 is a network-connected controller (“Radio”) that’s designed to allow HomeSeer (or Home Assistant) systems to manage Z-Wave (and optionally Zigbee) smart home devices. Since Z-NET is IP-enabled, it may be installed anywhere a network connection is available. Z-NET supports Network Wide Inclusion (NWI) for easy pairing of Z-Wave products. Multiple Z-NETs may be used together with any HomeSeer system for a centrally managed, muti-network installation; ideal for home owners with secondary residences, in-law apartments or outbuildings (pool houses, barns, workshops, sheds, etc).
- Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
- Supports Most Z-Wave Frequencies for Use Around the World
- Supports Z-Wave Plus (and older) Products
- Ethernet (and WiFi) Connections Allow for Optimal Positioning in Home
- Supports Network Wide Inclusion (NWI) for Easy Product “Pairing”
- May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
- Includes Highly Optimized Antenna for Superior Range and Performance
- Includes Easy to Use Web-Based Management Features
- Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
- Case Includes Keyhole slots for wall mounting (with your hardware)
Z-NET offers Z-Wave Plus controller performance in a network-connected configuration. This allows the unit to be installed anywhere a data connection exists (Etherner OR WiFi). This makes Z-NET the perfect choice for large residences and properties with outbuildings such as pool houses, barns, workshops or other quarters.
- Z-Wave Plus Certified
- Protocol: SiLabs Serial API
- Field-upgradable Firmware
- Supports all Z-Wave frequencies (configured in software).
