Z-Wave Smart Sensors
Our Z-Wave smart sensors offer innovation, performance, and affordability. The lineup includes motion, door/window, water leak, floodlight, indicator light, and multi-sensors, all featuring Z-Wave Plus technology and S2 encryption for top performance and security.
HSM200 Z-Wave Multi-Sensor
HSM200 is a Z-Wave Plus multi-sensor that may be used with your smart home hub to launch automations based on motion and changing temperatures & light levels. HSM200 also includes an RGB indicator light that may be programmed to glow different colors when things happen in your home.
- Motion, Temperature, and Light sensor
- Includes multi-colored LEDindicatorÂ
- Line-powered
- Works as a repeater
- Never needs batteries
- Supports Z-Wave Plus Technology
- Firmware updatable in field by end-consumer
- UPC: 610585164273
- PIR Range: 12′, 90° Coverage
- Temperature Sensor Range: -10 to 80°C, 0.1°C Resolution
- Light Sensor Range: 0-10,000 LUX
- Power: 120v, 60Hz
- US Z-Wave Operation
- Indicator Colors: Red, Green, Blue, Magenta, Cyan, Yellow, White
- Z-Wave Plus Certified
DS100 Z-Wave Door / Window Sensor
HS-DS100+ is a Z-Wave Plus door & window sensor that’s designed to update your smart home hub when doors or windows are opened & closed. HS-DS100+ supports S2 security, is easy to set up, takes regular AAA batteries and comes with all the hardware you need to install quickly.Works with most popular smart hubs.
- Door / window sensor
- Uses conventional AAA batteries for less battery changes
- Small and Sleek design
- S2 Security
- UPC: 610585164556
- Power: (2) AAA batteries
MS100 Z-Wave Motion Sensor
HS-MS100+ is a compact, easy to install Z-Wave Plus smart motion sensor that’s designed to report to your smart home hub when motion is sensed or when motion has not been sensed for a period of time. Use to track occupancy or monitor for security.
- Motion sensor
- Magnetic mount
- Easy to install
- Easy to adjust
- Works with most Z-Wave certified controllers
- Works on battery power or line power (adapter not included)
- UPC: 757347266292
- 908 MHz Z-Wave frequency
- Dimensions (main unit): 2″ x 2″ x 1.75″
- Micro USB port (for line power)
- Blue LED indicator
LS100 Z-Wave Water Leak Sensor
HS-LS100+ is a compact, easy to install Z-Wave Plus smart water leak sensor that’s designed to send Z-Wave commands when a water leak is sensed or has not been sensed for a period of time. Use with your smart home hub to issue notifications or to automatically control devices (like smart water valves).
- Leak sensor
- Designed for free-standing or wall mounted installation
- Includes optional magnetic wall mount (with probe cable)
- Supports S2 security
- UPC: 757347266308
- Dimensions (main unit): 2.5″ x 2.5″ x 1″
- LED indicator
