If you’re a home automation enthusiast using Z-Wave technology, you might be familiar with the Z-NET controller or HomeTroller hub. The HomeSeer 800 Series Upgrade Kit provides an option to upgrade your Z-NET or HomeTroller device to the latest 800 series technology, unlocking a range of benefits, including improved performance, greater range, and international compatibility. Let’s explore the key features, compatibility, and upgrade process for those considering this update.
What is the HomeSeer 800 Series Upgrade Kit?
The HomeSeer 800 Series Upgrade Kit allows you to upgrade your existing Z-NET or HomeTroller device—whether it’s a 500 or 700 series—to the newer 800 series. This upgrade improves overall performance, extends range, and supports the latest Z-Wave long-range devices. It’s an excellent option if you’re looking to enhance the functionality of your Z-Wave network without needing a complete system overhaul.
Key Features of the 800 Series Upgrade Kit
• Dual Network Support
The 800 series supports both Z-Wave mesh networks and Z-Wave long-range devices, allowing you to control both types of devices simultaneously. This dual network functionality means you can expand your home automation system more effectively, especially in larger homes or properties that require longer distances for communication.
• Z-Wave Long Range Support
Z-Wave long-range technology allows devices to communicate up to a mile away, which is ideal for larger homes, outdoor spaces, or installations with many physical obstacles. This upgrade will help ensure that your devices remain connected reliably, even in tough environments.
• Global Compatibility
With Z-Wave’s international support, the upgraded module can be configured to work with various frequencies used around the world. Whether you live in North America, Europe, or elsewhere, the 800 Series module can be set up to match the frequency requirements of your region, offering greater flexibility for international users.
• Enhanced Range and Performance
The upgraded 800 Series module comes with a highly optimized antenna designed to improve communication range and reliability. This ensures a stronger and more stable connection across your Z-Wave network, reducing connectivity issues and improving overall system performance.
• Easy Upgrade Process
Upgrading to the 800 series is relatively simple. The kit includes everything you need to make the transition, and the process is straightforward enough that most users can complete it themselves without professional assistance.
Compatibility & Requirements
The HomeSeer 800 Series Upgrade Kit is compatible with all models of Z-NET and with HomeTroller Zee S2, Pi or Pi G3. Before upgrading, make sure your system meets the following requirements:
- Your Z-NET or HomeTroller must be flashed with Z-Wave SDK v6.81 or higher.
- You will also need a HomeSeer HS4 hub with the Z-Wave Plus plugin, or a Home Assistant hub with the Z-Wave JS UI add-on.
If your device is running an older SDK version (v6.51), it can still be upgraded, but you’ll first need to update to SDK v6.81 using the 500 Series Upgrade Kit.
What’s Included in the Kit?
- 800 Series Z-Wave module HAT for Z-NET or HomeTroller controllers
- International Z-Wave Module for global frequency support
- Optimized antenna for better range and performance
- Field-up-gradable firmware
Why Upgrade?
There are several reasons why upgrading to the 800 series makes sense:
- Improved Range and Connectivity: With long-range Z-Wave support, you’ll be able to cover a larger area with fewer issues.
- Global Support: The module supports various regional frequencies, making it suitable for international use.
- Dual Network Capabilities: You can manage both Z-Wave mesh and long-range devices, offering greater flexibility and future-proofing for your system.
- Enhanced Security: The 800 series supports Z-Wave S2 security, ensuring your devices and network remain secure.
- Future-Proofing: The upgrade helps ensure your system can handle new devices and technologies as they are released.
How to Upgrade
The upgrade process is straightforward. Once you have the kit, you can replace the current module in your Z-NET or HomeTroller device with the 800 Series module. After installation, simply configure your system through your HomeSeer HS4 hub or Home Assistant hub, and you’ll be ready to take advantage of the enhanced features.
Conclusion
The HomeSeer 800 Series Upgrade Kit is a practical solution for Z-NET or HomeTroller users who want to improve their Z-Wave network’s range, performance, and security. With support for long-range devices, international frequency compatibility, and dual network functionality, this upgrade ensures that your system remains versatile and up-to-date as home automation technology evolves. Whether you’re expanding your system or just seeking a more reliable setup, upgrading to the 800 series is a smart move for enhancing your home automation experience.
Join The Discussion
If you have comments, suggestions or complaints, please tell us about it. We want to hear from you! The feedback we receive in the coming weeks will help us to improve the features and fine tune what dashboards will offer now and into the future.
