Imagine a home that monitors your climate, lights your rooms automatically and protects you and your loved ones from burglars and water damage. With HomeSeer, you can turn your imagination into reality with our latest Z-Wave powered smart home sensors.
HSM200 Z-Wave Multi-sensor
The HSM200 is a versatile multi-sensor. It not only detects motion but also monitors temperature and light levels allowing you to customize your home environment.
With its combination of sensors, HSM200 can help you manage energy usage in various ways. Use it to light any room when motion is sensed, but only when it is dark. Monitor temperatures in rooms without thermostats and use that information to better control your home’s heating and cooling strategies.
What sets this multi-sensor apart is that it is configured to glow different colors when certain events occur in your home. For example, you could set it to glow red when the garage door has been opened or yellow when the mail has been delivered. The unit can also be programmed to work as a night light after hours. To learn more about this unique feature, check out: the HSM220 Color Control Programming video..
Lastly, because HSM200 works on AC power, you’ll never have to worry about changing batteries, and because it uses wireless Z-Wave technology, it offers a very high level of performance and reliability.
FLS100 G2 Z-Wave Floodlight Sensor
Imagine, it’s late evening and you‘re waiting to receive a package and you’re worried that it may be misplaced or stolen. This is where the FLS 100 G2 Z- Wave Plus flood light sensor comes in handy. When installed, it detects motion when a delivery person approaches, turning on the floodlight and sending you immediate alerts. This sensor is designed to control floodlights and has a PIR sensor for precise motion detection. A built-in light (LUX) sensor monitors surrounding light levels, ensuring that your flood lights only turn on when necessary.
In addition, FLS100 sends Z-Wave commands to your smart hub when motion is sensed, or when there are changes in temperature or light level. Use these commands to trigger automation that sends notifications and controls other smart devices in your home. For example, you can turn on inside lights when it’s dark outside.
FLS100 is a drop-in replacement for standard 120v flood light sensors and can control flood light loads up to 300 watts. Settings are provided to change the ON time, vary the motion sensitivity, and test operation.
DS100 G8 Z-Wave LR Door/Window Sensor
If safety and security are important to you, consider the DS100 G8 Z-Wave LR door-window sensor. This sleek compact sensor is designed to send Z-Wave commands to your smart hub when doors or windows are opened or closed. Use these commands to trigger automations that send notifications or control other smart devices in your home. For example, turn on lights when someone walks through a door or get notifications when your mailbox lid has been opened. Issue an alert if you leave home and forget to shut the windows.
The sensor uses conventional AAA batteries for convenience and its efficient operation ensures low maintenance and fewer battery changes. Naturally, Z-Wave S2 technology is supported ensuring the highest level of security. The DS100 G8 is a must-have for any smart home, as it is simple to set up and works with the most popular smart hubs.
MMS100 G8 Z-Wave LR Motion Sensor
MS100 G8 is a PIR (passive infrared) sensor that’s designed to send Z-Wave commands to your smart hub when motion is sensed or has not been sensed for a time. Use these commands to trigger automations that send notifications or control other smart devices in your home. This makes the sensor particularly well suited for creating security and occupancy-related automations. Did someone just break into your garage? MS100 can tell you! Do you want to turn the lights on when someone enters the bathroom? MS100 can help you do that!
MS100 is very compact and includes a long-life lithium battery and a magnetic mount for easy installation and setup.
LS100 G8 Z-Wave LR Leak Sensor
LS 100 G8 is designed to detect water and may be used in a variety of ways such as protecting your home from water damage or monitoring the water level of toilet tanks, dehumidifiers, and other similar appliances. LS100 sends Z-Wave commands to your smart hub when water is detected or has not been detected for a time. Use these commands to trigger automations that send notifications or control other smart devices in your home. Want to shut off the water when a leak is detected? LS100 helps you do that! Want to be notified if your toilet flush valve isn’t sealing properly and needs to be replaced? LS100 to the rescue again!
The sensor is designed for free-standing or wall-mounted installation and comes with an optional magnetic wall mount and probe cable for increased versatility. This sensor is an essential element for any smart home and is compatible with most smart home hubs.
PS100 G8 Z-Wave LR Presence Sensor
HomeSeer is excited about the upcoming launch of the PS100 G8 Z-Wave Presence Sensor. This is a new breed of sensor that uses high-frequency millimeter wave technology to detect very small movements from people, pets, and objects. This makes PS100 the ideal solution for tracking room occupancy and for a wide variety of security needs.
Unlike conventional PIR (passive infrared) motion sensors which can become ‘blind’ to people who are motionless for a time, PS100 is sensitive enough to detect people breathing or even sleeping.
PS100 works seamlessly with most smart home hubs including those from HomeSeer, SmartThings, Home Assistant, and Hubitat. Its flexible multi-position mount makes installation effortless. Use it to trigger automations that send notifications or control other smart devices in your home.
In Conclusion...
Whether you want to improve security, conserve energy, or simply control your home more conveniently, HomeSeer smart sensors are here to help! Elevate your smart home living experience today with HomeSeer!
