The Release of HomeSeer’s SmartStick ZB
HomeSeer is releasing its brand new SmartStick ZB Zigbee Dongle
HomeSeer is proud to announce its latest product, the SmartStick ZB. Our SmartStick ZB is compatible with HomeSeer, Home Assistant, OpenHAB and Zigbee2MQTT, as well as supporting Zigbee 3.0 functions. Giving you versatile options to integrate Zigbee devices and expand the possibilities in your smart space.
Introduction to the SmartStick ZB
Priced competitively at $31.99 the SmartStick ZB is a high-quality effective  Zigbee integration solution at a low cost. Our SmartStick boasts +20 dBm max output power and a high-gain +5 dBi detachable antenna, giving it a further range than most DB dongles on the market. The SmartStick is Powered by Silicon Labs ERF32MG21 Chipset: Built on the latest-generation Zigbee SoC, offering enhanced signal processing, energy efficiency, and support for a greater number of connected devices. It is compatible with  HomeSeer, Home Assistant, OpenHAB and Zigbee2MQTT systems and is future-proof with its field upgradable firmware, ensuring the device stays up to date and compatible into the future.
About Zigbee
Much like Z-Wave, Zigbee is a transmission protocol that is commonly used in smart-devices. It operates at frequencies of 2.4GHz to 915MHz in North America and has a data rate of 250kbs. Zigbee devices have a range of 33-328 feet indoors and a hypothetical range of around  980+ feet outdoors with some devices. Due to its relatively low power consumption Zigbee devices often have impressive battery life, only requiring replacement batteries twice a year on the low side but potentially once every two years in the case of some products. Zigbee devices offer additional security through the use of a 128-bit AES encryption.
Why might you consider adding Zigbee to your system?
We are well aware that at present the smart-home market is often inconvenient because not all device providers create products across all protocols, leaving many wanting for more. That is where increased integrations and dongles come in.
The biggest advantage of integrating zigbee into your system is the increased variety of devices you will have access to. There are over 1000 devices certified for Zigbee 3.0 for you to select from including sensors, smart cameras, lighting, smart outlets, curtain controls, and much more. With the SmartStick ZB you will be empowered to include any of these fine products into your system.
Now Available
We at HomeSeer are proud to continue to provide high-quality devices to suit our customer’s needs.
If you are interested in adding Zigbee to your system then feel free to drop by the HomeSeer store and get your HomeSeer SmartStick ZB today.
Sources
  • https://homeseer.com/hs-products/hubs-interfaces/smartstick-zb
This website uses cookies
